Unread 03-26-03, 01:17 PM
Dale Campbell's Avatar
Unhappy Rear Fire Wall Leak
I had a simmular problem & it turned out to be. Water came in through air scoop on rear engine & down the fire wall to inspection covers that had poor seals than down inside fire wall to carpet. You need to pull back interrior on fire wall & use water hose around scoop area, to see where it is getting in. Have fun some times leaks are hard to find. Dale Campbell
