Unread 06-10-03, 08:12 PM
Ron Ball Ron Ball is offline
Ron Ball is an unknown quantity at this point
Riley air conditioning
My Riley air-conditioning circuit breaker pops when AC air is turned on . The 10 amp breaker pops.. The fan turns on . I disconnected the wire to the electric clutch, on the condensor and the breaker is O.K. Called Tule River where they installed it and they said is an automotive type and need to replace. They mentioned to check the diode on the unit, can't find it.Anyone have this problem? The breaker pops immediately , so it appears to be a short. Would a bad diode cause this? If I can find the diode[ not on the schematic] can it be replaced , without taking out the condensor?
