Unread 04-15-03, 06:04 PM
Question Skymaster Checklist
I am a pilot who is about to start a job flying a Skymaster. In order to get a start learning about the airplane can somebody post the checklist they are currently using.
If its easier just email to: engagethesimulator@yahoo.com
Unread 04-15-03, 08:40 PM
Frank Benvin's Avatar
Please provide year & model Check lists vary between aircraft
Frank
Unread 04-16-03, 07:53 PM
I believe its a 1969 337. Thats very much for the prompt reply.
Unread 04-17-03, 08:01 AM
Skysmith
Scott smith, skysmith, will sell you a laminated set for not much $$. It is model year specific, as I remember.
If you have a fax number, I can fax you what i have
Unread 04-17-03, 04:29 PM
If your flying a 1969 skymaster with long range tanks. Make sure you read this. Someone please confirm that this applies to the 1969 Model I have a 1967
http://www.miramaryachtclub.com/337fuel.htm
Frank
Unread 04-27-03, 02:57 PM
Frank:
Yes, it applies to a 1969. I also think it applies to 1965-1968 models with four tanks, and I have included a diagram of the fuel system to allow you to compare it to yours. By the way, an easier to remember address is www.SkymasterUS.com and then select Fuel Supply Management.
On the original topic of this thread, dealing with Checklists, please note that I can send you one of these if you go to the web site address given above and then select Skymaster Checklists.
Ernie Martin
