Unread 03-24-03, 04:37 PM
Pressurized Baggage Pods
Hi folks.
In a conversation this morning with a gentleman who is perhaps interested in buying my P337, the subject of baggage pods came up, and it made me want to ask a question of this group:
Over the years, I have seen messages from a number of folks, and when I had a pod for sale I talked to folks, who were looking for a baggage pod for a P337. I keep hearing rumors that pods are or were manufactured for P337s, either by Cessna or somebody else. But I have never seen one, nor actually talked to someone that had one. I have seen *lots* of pods for normally aspirated Skymasters, but never for a pressurized. To my knowledge, RT Aerospace's pods are for normally aspirated airplanes only. So here are my questions:
1.) Do you know of a source for a baggage pod for a P337?
2.) Do you have a baggage pod on your P337, or on one you fly?
3.) Have you ever seen a baggage pod mounted on a P337?
Thanks in advance for your help.
Unread 03-24-03, 09:02 PM
pods
> No such thing as a pressurized pod <G>.
> It cuts your fuel range and chews up airspeed besides cutting your useful load.
> Had to fit around airconditioning which is more valuable unless you live in the damp, cold, wet, foggy, rainy, northwest......
> I have never seen or heard of one on a "P".
Like putting army boots on to jog......
Unread 03-25-03, 03:55 PM
IMHO
Kevin,
The pod mounts to the bottom of the airplane, and since you seal the floor, it should be doable. I know that Chachi has a pod on his '73, which is the same configuration as your pressurized model.
It should be very doable.
Unread 03-25-03, 07:23 PM
Larry, yes as you can see mine has the pod but it is a normally aspirated 75, 337G. Never heard of, or saw a P337. Chachi
Unread 03-27-03, 04:13 PM
Pat Rolfes Pat Rolfes is offline
Pat Rolfes is on a distinguished road
Chachi-
Fabulous paint job!! My pod has a lighter color paint and I am constantly scrubbing exhaust remnants from it. I suspect repainting the pod would save alot of elbow grease.
Pat
Unread 03-28-03, 11:30 AM
Pat, with the dark color on the pot and the rear engine you do not have to worry about how clean it looks after every flight. I used a dark green
Unread 03-31-03, 06:54 PM
I checked the Cessna Parts catalog for P337's and they did install cargo pods on P337's (ref figure 149 of P337 IPC). Since our pod is dimensionally identical to the Cessna pod, adding the P337 to our STC effectivity is not a problem.
I would probably revise the Cessna installation instructions to require small doublers at the attach points through pressure skin (forward attachments).
Regards,
Ray Torres
RT Aerospace
