Old 02-24-03, 10:57 PM
Francisco's Avatar
Vacuum gauge inop
While doing a run up, I noticed the Vacuum gauge was not working it was CAVU, and I wanted to make sure the giros where ok - they are. So what can cause the gauge to stop working?
Also the Rear engine Fuel Pressure ( Fuel Flow) middle in the dual gauge is not working. We replaced the Mechanical fuel pump during the annual and the pump works find any suggestions?
Any help is appreciated
Francisco
Old 02-25-03, 10:51 AM
FRED-E's Avatar
FRED-E FRED-E is offline
More Info
Need to know, model, year, ser#, normal asp, etc.
Fred N358
Old 02-25-03, 06:09 PM
gauge
Are the red buttons in or out. Is it just the needle indicator that's not working. working?
Old 02-25-03, 06:56 PM
Francisco's Avatar
1964 Cessna 336 S# 336-035 Scuse my speling I ment needle not Middle
Thanks Francisco
Old 02-25-03, 07:04 PM
Francisco's Avatar
Yes Jerry it is the Needle on the rear engine fuel flow that does not work, also the same with bouth vaccum indicators
Thanks Francisco
