Unread 11-26-25, 06:12 PM
Burt Burt is offline
Dukes Fuel Pump
Does anyone know where I can get parts for my Dukes aux fuel pumps? They are very easy to overhaul if parts could be found.
Unread 11-27-25, 09:39 AM
Frank Benvin's Avatar
I bought complete units from aircraft accessories You can check if they sell parts
https://aircraftaccessoriesofok.com/
Frank
1967 337B
Unread 11-27-25, 06:45 PM
Thanks, I will check with them.
Unread 11-29-25, 10:55 PM
Joes Joes is offline
PMAD Weldon 18000 Fuel Pumps
Unread 11-30-25, 11:32 AM
This pump is only certified for the E model and newer -
Good for these models - 337E, 337F, T337E, T337F, F337E, F337F, FT337E, FT337F, 337F, T337G, P337H, FT337GP, FP337H, 337G, 337H, F337G, F337H, T337H
I have a 337b and replace it with the dukes as it was certified for my 337
Frank
1967 337B
Unread 12-09-25, 10:23 AM
Dukes Fuel Pump
After an exhaustive on-line search and many phone calls I gave up trying to find the part that I needed and ordered a new pump so I will be back in the air in a few days. I am keeping my old pump since it was functioning perfectly except for a very slow leak along the shaft due to the "bearing and seal assembly" being worn. It still has many serviceable parts including the motor.
I discovered that McFarlane lists most of the parts for many aux pumps but not the part that I needed. McFarlane owns CJ Aviation which is the only authorized repair/overhaul facility for Dukes pumps that I could find in addition to the original manufacturer but CJ will not release the part that I needed. And of course Aero Fluid Products (formerly Dukes Aerospace) does not sell any parts but they will repair/overhaul my old pump. So I may send them my leaking pump to fix and keep it for a spare.
Burt
Unread 12-09-25, 02:13 PM
Thank you for sharing the information. Good Luck..., Ed
Unread 04-26-26, 06:05 AM
Don’t bother overhauling a Duke. Just get a new pump CJ aviation fuel pump.
Unread 06-25-26, 11:55 AM
Jhazelip Jhazelip is offline
Jhazelip is on a distinguished road
Weldon 18000B Fuel pumps
The Weldon 18000B fuel pump is an alternate part number to the 1426033-3, 4140-00-15, 4140-00-15RX, and C291504-0101 PN pumps per Textron. It is legal to use in the A-D Skymaster.
Unread 06-25-26, 09:42 PM
Weldon shows it only good for E model going forward
PMA Application and Pump Cross
Reference
Cessna (FR172K S/N FR17200621 & Up, R172K S/N R1722725 & Up, R182/TR182
S/N R18200584 thru R18201628, 177RG S/N 177RG1267 thr 177RG1366, A185F S/N
18503459 & Up 188, A188, 188A, A188A, 188B, A188B, 206, 206H, P206, P206A,
P206B, P206C, P206D, P206E, T206H, TP206A, TP206B, TP206C, TP206D, TP206E,
TU206A, TU206B, TU206C, TU206D, TU206E, TU206F, TU206G, U206A, U206B,
U206C, U206D, U206E, U206F, U206G, 207/T207 S/N 20700228 & Up, 207A, T207A,
210H, 210J, 210K. 210L, 210M, 210N, 210R, T210H, T210J, T210K, T210L, T210M,
T210N, T210R, P210N, P210R, 337E, 337F, T337E, T337F, F337E, F337F, FT337E,
T337H)
18000-B C291504-0201 4140-00-15 Fuel Boost
Cessna FR172K (S/N FR17200621 & Up), R172K (S/N 1722725 & Up), T182 (S/N
18267716 and up), TR182 (S/N R18200584 and up), 177RG (S/N 177RG1267 thr
177RG1366), A185F (S/N 18503459 & Up), 188, A188, 188A, A188A, 188B, A188B,
206, 206H, P206, P206A, P206B, P206C, P206D, P206E, T206H, TP206A, TP206B,
TP206C, TP206D, TP206E, TU206A, TU206B, TU206C, TU206D, TU206E, TU206F,
TU206G, U206A, U206B, U206C, U206D, U206E, U206F, U206G, 207/T207 S/N
20700228 & Up, 207A, T207A, 210H, 210J, 210K. 210L, 210M, 210N, 210R, T210H,
T210J, T210K, T210L, T210M, T210N, T210R, P210N, P210R, 337E, 337F, 337G,
337H,, F337E, F337F, FT337E, FT337F, FT337GP, F337G, F337H, P337H,T337E,
T337F, T337G, T337H
XC18000-B C291504-0201,
C291504-0202
4140-00-15,
1515-00-1NV,
18000-B
Fuel Boost
1967 337B
