Unread 11-22-25, 01:22 PM
Jhogan0101's Avatar
How do you top off your hydraulic fluid?
I currently use a pump sprayer with push to connect fittings.
It works but leaky and messy.
Looking for a better way…
337B
Philadelphia PA
Unread 11-22-25, 06:49 PM
Joes Joes is offline
I have used a levered oil can forever, such as an ARES 55010 – 16oz Red Lever Style Oiler Can. This is just an example of the type of oil can. I only get one use from the cheap plastic hose; the petroleum makes the soft plastic rigid. If there was a leak I would pull a vacuum from the caliper using a snap-on brake vacuum; nothing wrong with the fluid, and it can be reused.
Unread 11-23-25, 04:27 PM
GOLDENROD metal oil can with flex metal line
GOLDENROD (727) Industrial Pump Oiler with Flex Spout - 16 oz. Capacity
Metal pump can with flexible metal line and end cap.
Can store fluid and close. Threads into fitting on hydraulic paclk
I just topoff periodically until it drools out the overflow below the engine.
Also, with short plastic tube, also great for filling brakes from below.
Put towel over pedals and again, fill until it drools out the top of the brak cylinders.
Drool drool, everywhere...
Unread 11-25-25, 07:00 PM
general's Avatar
general general is offline
Goldenrod
GOLDENROD here
General Sky
