Unread 05-13-02, 03:37 PM
GMAs GMAs is offline
George M. Amthor, Jr.
Those that flew to Treasure Cay....
BY THE WAY....
I hope you all washed your planes down... found a rain storm to fly thru... (automatic plane wash).... or left it out so that the fresh water from the rain or garden hose... flushes all the salt spray out... remember... that after going to islands or around the ocean.. you need to wash out the plane... flush with lots of fresh water ... in as many places as you can... and the only time you should spray water backwards on the wing... to get into the cracks and crevices... to get the salt out as much as you can... Scrub scrub.... everything... and if its raining outside... good place to leave the plane for a rinse... then get out the oil cans and lube...lube... lube.... wipe off the old exposed grease and replace with new... most of you will have put 25 to 50 hrs on by now... so check the service manual and do all the items... as well as all exposed wearing surfaces need cleaning and lubing... makes the plane last longer.... smile... GMAs...
Unread 05-14-02, 05:16 AM
Notes from Treasure Cay.
Gmas, your discussions at TC sound great and I will make more effort to get the the next meeting. That said, are the notes from your briefings available or could they be made available.
Dave Underwood N456TL
Unread 05-14-02, 06:25 PM
For Gmas, George, thanks a bunch for the excellent presentation. Your knowledge of the Skymaster is tremendous and sharing it with us speaks highly of your caring personality.
Thank you
