Unread 01-13-24, 03:49 PM
Burt Burt is offline
Fuel Flow indicator
Anyone happen to have fuel flow (pressure) indicator that you don't need?
Part #S1513N2
Unread 01-13-24, 08:23 PM
Burt,
I don’t have that, but I do have the twin-engine Shadin digiflo system (two flow transmitters and cockpit gauge) if you want to go that direction.
I removed it from my aircraft when I installed the GI275 EIS.
-LJ
Unread 01-15-24, 05:15 PM
kbecker kbecker is offline
I may have one of these on the shelf at the hangar. Will check on Thursday if you can wait until then.
Unread 01-15-24, 07:07 PM
I have one on eBay, not sure of the condition and selling as a core
P/N 1252981
Unread 01-18-24, 05:37 PM
Here is the one I have. Let me know if this works for you.
File Type: jpeg 93ACFEE8-8127-4896-A8FC-625A119D86A7.jpeg (249.5 KB, 2754 views)
File Type: jpeg 7F100F02-4380-4617-91EE-0BB569F207AE.jpeg (246.1 KB, 2726 views)
Unread 01-19-24, 10:40 AM
Consideration
Unless you are trying to maintain the antique style, I'd step up to a shadin or equivalent.
I was the first person to put a shadin in my helicopter in the 1980's. A helicopter fuel gauge is only accurate sitting on the ground with the engine off ...for at least 3 minutes.
The 337 turbo fuel flow meter is actually a pressure gauge that must be connected to the fuel manifold, as I recall, and to the turbo outlet pressure.
Double check that, it was 25 years ago.
I wasn't thrilled with a fuel line over my passenger's knees.
I recall from 25+ years ago the rear cessna fuel flow gauge would jump to 20 gph on idle because the vacuum side to the gauge would drive it nuts.
A Shadin, or equivalent, will give you a lot more utility. More accurate, of course, but also gives you lots of other info if connected to any sort of GPS system.
