Unread 09-28-23, 05:09 PM
Scudrunner's Avatar
Scudrunner Scudrunner is offline
Scudrunner is on a distinguished road
Tire Tube Valve Stem Type
Its about time I changed my tires out I have the larger 18 X 5.5 8ply which are easy enough to find.
However when looking for Tubes I found several types of Stems available.
TR-15
TR-67 70 Degree Tube Metal Valve
I have always thought the stems on mine where short (ish) what are you folks running before I hit the checkout button.
Not the best pic and yes I’ll be having those sand blasted and repainted.
Unread 09-28-23, 10:15 PM
Aircraft spruce has the tube.. As I recall, I got the Desser tube, with the TR-15 valve...
I will check my records, and get back to you..
Unread 09-28-23, 10:22 PM
Yep... I was correct.
Unread 09-28-23, 10:30 PM
Scudrunner's Avatar
Appreciate your quick response !
I was about to click the checkout button but recalling I thought the valve stem short I thought I would ask to be sure.
I pondered the previous owner (only had ours 2 years) might have not got the correct ones. The logs only showed them replaced and lot number no part number. 🙄
Great site appreciate all the knowledge on here.
Unread 09-28-23, 11:17 PM
Deleted this item.
