Unread 06-21-23, 11:34 PM
nick nick is offline
nick is an unknown quantity at this point
Insight engine moniter
Brand new Insight engine moniter with harness including all new probes 5k.
Unread 07-03-23, 01:40 PM
Shanmoon's Avatar
Shanmoon Shanmoon is offline
Shanmoon is on a distinguished road
Is this the Insight G4 Twin?
Classic Searey and Skymaster 337G owner, former 337D owner
Unread 07-03-23, 08:34 PM
Insight G4 twin
This unit is a G4 twin set up for a
1973 T337G
Unread 07-27-23, 04:58 PM
Alainb Alainb is offline
Engine Monitor
Hello
I have a FTB337G -1975 in Europe.
I am thinking to install an engine monitor. Does The G4Twin give you Fuel quantity as primary ?
Alain
Alain
+41 79 266 2000
www.evazion.ch
www.osud.ch
www.Whitepod.com
www.purplewings.ch
Unread 07-28-23, 10:28 AM
it does have a fuel computer but NOT as a primary unit
Unread 07-28-23, 03:58 PM
G4
Hello
Thanks for your replay.
So you need to insert the full quantity you have in your tanks and then the fuel computer will give you remaining fuel etc etc ?
Yours have all document and certification ?
Alain
+41 79 266 2000
www.evazion.ch
www.osud.ch
www.Whitepod.com
www.purplewings.ch
Unread 07-29-23, 11:02 AM
yes fuel computer does that and I do have all the paperwork
Unread 01-07-24, 10:15 AM
Insight G4 considerations
What does this G4 include?
There is the basic EGT CHT
Then options for
Fuel flow, which requires either dual sensors or interface to exisiting sensors
Vibration, which requires RPM
Engine power, which requires dual OAT
The only cert as primary is to replace EGT and CHT, all other is 'advisory/supplemental'
The advisory are better than the certified, but you can't pull the old ones out.
From what I've found so far, 100% replacement options for primary gauges are
1. Some combination of multiple Garmin 275s (apparently $13k+ in parts)
It looks like one would need 2-3 gauges. One for each engine then one for tanks?
2. Electronic international the electronics international 'CGR' suite $12k in parts
Then maybe another $3-5k to install.
It looks like it drops to $9k if you trade in, but that assumes you are using existing sensors already installed from prior engine analyzer.
https://iflyei.com/wp-content/upload...ombo_Sheet.pdf
3. Or EI's twin package MVP package
https://iflyei.com/product/mvp-50p-engine-monitor/
This requires panel cutting so install cost probably quite a bit more.
I'm actively considering an engine analyzer, BUT.....that old 'cost/benefit thing
Unread 04-28-24, 02:08 PM
Still for sale?
