Unread 10-11-22, 02:11 PM
Front turbo wastegate actuator seep
Tired of seeping from the oil inlet actuator, gonna try a nut that has a Teflon backup ring for the oring. Will see if it works better
File Type: jpeg CF56F57A-4246-48CB-A0EC-973E7FFCBB03.jpeg (124.7 KB, 1669 views)
Unread 10-19-22, 08:22 PM
Ended up being the small oring on the treaded post with the lock washer and nut. Unfortunately I did not replace it when I replaced the piston seal and expander. Not too big of a job though, easy to disconnect the actuator from the waste gate.
Unread 10-22-22, 04:38 PM
I'm glad you figured it out.
