Unread 12-18-21, 07:33 PM
Jhogan0101's Avatar
Are these levels normal? 337B
I was flying yesterday at 4500’ and these were my readings.
The settings on both engines were the same and that is why i am questioning.
Front Rear
Oil pressure 37psi 51psi
Oil temp 135F 136F
Tach 2200 2200
Manifold 22.0 22.0
Fuel pressure 7.4 8.3
337B
Philadelphia PA
Unread 12-21-21, 09:58 AM
That's awesome you have the same oil temps - my rear tends to run warmer. I have a slight fuel flow difference as well between engines when set up the same and leaned appropriately. You can adjust your oil pressure if you are concerned, but I all looks pretty good to me.
Unread 12-23-21, 06:50 PM
Jhogan0101's Avatar
Thanks Jeff, i guess my OCD is getting the better of me. Readings not being almost identical bothers the hell out of me. I guess i just need to “let it go” lol. Thanks.
337B
Philadelphia PA
