Unread 10-03-21, 02:05 PM
Parting out P337-0022 N3CY
I purchased our relic P337 that has sat outside our private airport 3OH0 for approximately 30 years. I am keeping the windshield deice plate and some others parts for my 74 model. About 2800 hrs deice system, O2 system, etc, engines appx. 1200 hours 1978 factory remans.
Let me know what you might need.
Dan Schultz
Tipp City, Ohio
937-603-2459
Schultzav@woh.rr.com
Unread 10-04-21, 07:16 PM
What's the interior color? Is any of it still useable?
Welcome to the used airplane parts biz!
PS - I've seen this plane before online. Here's a pic:
Name:  P337 in ohio for parts.jpg
Unread 10-05-21, 04:44 PM
Exclamation
Sent an email and left a voicemail, but I haven't heard back from you. Check your PMs as well please.
Unread 12-06-21, 10:59 PM
Sorry,
Interior is red, front seats are spoken for, and the fifth seat, middle seat is in pretty good shape. Side panels will clean pretty well.
Dan
937-603-2459
Unread 12-07-21, 10:36 PM
bjornfb bjornfb is offline
I could use the rear air scoop (the big top one) - that whole piece.
-Bjorn
Unread 01-31-22, 09:37 PM
Alanw Alanw is offline
Alanw is on a distinguished road
I’m looking for engine probes if there is a monitoring system in there.
Unread 02-01-22, 07:09 AM
No monitoring system.
Unread 02-01-22, 09:31 PM
Alanw,
What probes are you looking for? I have 2 factory CHT probes I just removed from my engines.
Unread 02-04-22, 11:54 AM
I think I have the factory ones. I believe I need the needle ones and right now 12 CHT and 12 EGT probes.
Unread 05-18-22, 04:14 PM
Cap.jensen Cap.jensen is offline
Cap.jensen is on a distinguished road
Prop syncro
Hi Dan
Does it have the prop cyncro boxes
Regards
Jesper
The boxes I have are Synchrophaser SP100A pn 42150 0000
and sp105B pn 43380 0001
Unread 05-20-22, 08:49 AM
Jesper
yes it does, both governors, brain box, box for the rear prop adjustment, one prop unfeathering accumulator, rear accumulator is missing.
Dan
Unread 05-23-22, 12:39 AM
hayesjaj hayesjaj is offline
Originally Posted by Cap.jensen View Post
Hi Dan
Regards
Jesper
If Dan doesn’t work out for you, I just removed them from my 337G. Main sync box and rear actuator as well as at least one of the sensors. No governors (they were not repairable).
Unread 06-22-22, 02:51 PM
MLG Doors
I'll take the main landing gear doors if they are not too bad. Could you post some pictures?
Unread 03-21-23, 03:22 PM
chrisb chrisb is offline
chrisb is on a distinguished road
Email sent
P337H Sn: 0318.
Under restoration
Unread 03-27-23, 10:30 PM
bwbth bwbth is offline
bwbth is on a distinguished road
door seal available
is the door seal still good? I could use one if it's available.
