Unread 02-27-21, 03:31 PM
hayesjaj hayesjaj is offline
73G Nose gear bolt torque
Easy one, but does anyone know the torque numbers for the nose wheel bolts? It’s the original 3 piece Cessna assembly and it doesn’t have the data plate with the info on it. The maint manual doesn’t list it specifically for the wheel. Thanks!
Unread 02-28-21, 12:50 PM
Depends on P/N - do you know it?
You do need to know what the part number of the wheel is - D-30204, D-30255, etc.
Here is link to torques by P/N:
http://www.rapcoinc.com/pdf/Informat...ue%20Spec..pdf
Here is a link to possibly determine your wheel P/N by drawings - see page 202 to see if that is the one...:
https://www.parker.com/literature/Ai.../AWBPC0001.pdf
Unread 02-28-21, 01:17 PM
Thanks! I should have noted it was a D-30204. The listing (95 in-lb) is exactly what I was looking for, thanks.
