Unread 11-19-20, 01:27 PM
T337G in IRELAND! $33k
Sounds partially dissembled: https://www.trade-a-plane.com/search...-type=aircraft
Unread 11-19-20, 03:08 PM
JimC's Avatar
JimC JimC is offline
The pilot's window opens! Does anyone know if that can be retrofitted to earlier models?
1969 T337E
Unread 11-19-20, 06:53 PM
Its one of those bubble windows. I've never seen one on a 337, but they are popular with the 172/182 crowd.
Unread 11-19-20, 07:14 PM
JimC's Avatar
It's not just a bubble - it's a bubble on a hinged frame. I haven't seen that before.
Anyone know how to go about getting that conversion?
1969 T337E
Unread 11-19-20, 08:00 PM
https://www.globalparts.com/sale/det...5Yr0PzrAKuWP00
Unread 11-20-20, 09:51 AM
JimC's Avatar
Herb - are you suggesting that one has it?
I've been doing some google photos research - it appears that some (maybe all?) F337Gs had hinged pilot windows - I've found more than one. The 337Gs from Cessna do not.
1969 T337E
Unread 11-20-20, 01:07 PM
Did you see this close-up of the window? The second pic is the passenger door - they added three windows to it! What is the "air deflector" thing mounted in front of the passenger window???
Unread 11-20-20, 01:17 PM
It has a ROLLS ROYCE TSIO-360! Even has RR on the rocker covers - How cool is that?
I just noticed that it has the 225HP engines installed at the factory instead of the usual 210HP engines. So essentially its a Turbo Skymaster with the engines from a Pressurized Skymaster - 30HP more than any other Turbo model!
No wonder Reims used it as the military demo model!
