Unread 10-28-20, 12:06 AM
paul.j paul.j is offline
paul.j is on a distinguished road
Front Prop for 337G
Hi all,
I am looking for a front (2 blade) prop for a 337G. Please let me know if anyone out there has one.
Thanks.
Unread 10-28-20, 11:35 AM
There's one on Ebay for about $2200 IIRC.
EDIT: Here it is, make an offer: https://ebay.us/uu9I5R
Unread 10-28-20, 04:30 PM
Frank Benvin's Avatar
That prop is for a 66 It can not be used on a 73 check AC6E
XIII - Model 337G, 4-6 PCLM (Normal Category), Approved December 18, 1972
Engines (Both) Continental IO-360-G or -GB
*Fuel 100/130 minimum grade aviation gasoline
See NOTE 5
*Engine Limits For all operations, 2800 r.p.m. (210 b. hp.)
Propeller and 1. McCauley constant speed full-feathering propeller installations
Propeller Limits (a) S/N 33701463 through 33701748:
(Front) McCauley D2AF34C306/78CAA-0
Diameter: not over 78.0 in., not under 76.5 in.
No further reduction permitted
Pitch settings at 30 in. sta.:
low 11.0°, feathered 82.0°
(b) S/N P33701449, 33701749 and up:
(Front) McCauley D2AF34C310/90DEA-12
low 9.9°, feathered 82.0°
(c) (Rear) McCauley D2AF34C307/L78CBA-2
Diameter: not over 76.0 in., not under 74.5 in.
low 11.0°, feathered 80.0°
(d) (Front) McCauley hydraulic governor CF310D1/T1 or CF310D2/T1
1967 337B
Unread 10-28-20, 08:03 PM
JimC's Avatar
JimC JimC is offline
There are always a few props on Barnstormers.
https://www.barnstormers.com/listing.php?catid=17416
1969 T337E
Unread 10-28-20, 08:21 PM
Try Tiffin Aire, Tiffin, OH. Ask for Mike Baird. I gave him my front prop from my 73 G model that was rejected from Aircraft Propeller Service earlier this year. I bought a new front prop but Tiffin Aire overhauled my front prop governor.
Mike emailed me shortly after I gave him the prop and in his judgement the blades were serviceable but the hub was no good. He has given me a credit which will be applied when my rear governor gets sent to him in the next couple of months for overhaul. My guess is I'll be buying a new rear prop soon but who knows.
Anyway, maybe he still has the blades and if a front hub could be located, (which I could not find) maybe you could get lucky.
I worked with "Propeller Man" in Florida (which was ironically a woman) for the new front prop. Service was excellent and they beat several other quotes by about $2000. If I need a new rear prop this coming January, they will be getting my business again.
Good Luck, I did not have much myself while searching but that doesn't mean you shouldn't try. Yes, periodically, a prop will show up on Barnstormers, but if it doesn't have a pedigree, it's a big risk as you have no clue what your buying until a prop shop gives it's blessing.
Unread 10-30-20, 11:58 AM
Exclamation
Contact Paul Schaffer at Top Flight Props in Las Vegas. They show to have an overhauled one in stock ready to go - 702-466-7197
Correct P/N too - McCauley D2AF34C310/90DEA-12
Unread 10-30-20, 01:32 PM
Thanks so much everyone, will pursue these avenues!
Blessings.
