Unread 03-27-20, 05:28 PM
Jhogan0101's Avatar
Bell Mech Cowl Kit
Anyone have this installed?
How difficult to operate during flight?
Unread 03-28-20, 08:14 PM
YankeeClipper's Avatar
If there is only one mechanical cowl actuator, then I have one. It's a little stiff, but nothing of concern. Mind you, that's the front. With all of the extra distance and the 180 degree turn on the cable, I can image the rear would be a bit hard to actuate.
Unread 03-28-20, 08:15 PM
Oh ... and don't make fun--the panel is a work in progress.
Unread 03-30-20, 09:04 PM
What's the price of the mechanical mod
Unread 03-30-20, 09:22 PM
Jhogan0101's Avatar
Herb,
Owen has it listed on his site for $1495
I called him to buy it, he said web price is a mistake and to order i needed to wire him $2995 (my plane came with an aftermarket not signed off hybrid 172 motor, ap said he had to remove)
I did and got the kit 2 months after i ordered it.
Recently during my annual, Craig went to put the kit in, and the front control pull handle was missing. I called Owen and said we didnt get the front cable, he said he would send one for $995.
I called Don to try and get the cable for a reasonable price but he said he probably didnt have and mech kit is bad idea because its too difficult to move it in flight. Thats the reason for my post anyway.
http://www.cessnaskymaster.com/mech-...ol-system.html
Unread 04-01-20, 02:42 PM
Herb,
I called him to buy it, he said web price is a mistake and to order i needed to wire him $3500 (my plane came with an aftermarket not signed off hybrid 172 motor, ap said he had to remove)
I did and got the kit 2 months later.
Here is how I read the website above, $1495.00 each (front or rear) PLUS your good Cowl Flap Motor that you removed to put his cable system on. It's how I see it, thoughts?
Cost for the front or rear conversion Kit (T-handle control cable, cable support brackets for each end, lever arm to attach to torque tube)
$1495 exchange for your repairable cowl flap motor.
Unread 04-01-20, 03:19 PM
Jhogan0101's Avatar
Thanks Herb,
I can understand that. Here is what he actually sent to me
“To begin, the old price showing on the web site is several years old.
I have contacted the web coordinator to update the web site.
The current price for either a new PMA cow flap motor or mechanical cowl flap system kit is $2995.00 with up to $500 rebate for an economically rebuildable cowl flap motor.
It is easier and better I believe to simply replace the motor and make sure that the microswitches are adjusted properly.
Please advise which you want, the replacement new motor or the mechanical system.
Also please advise the ship to address and if you have a shipping account number or if you want us to add the freight charge.”
File Type: png A1722FE4-4CF0-47C0-BA8E-78B18447AB9B.png (103.0 KB, 2299 views)
337B
Philadelphia PA
Unread 04-02-20, 10:46 AM
Thanks Herb,
Is the $2995 for one cowling or both? If it's for one then you got a better deal on your kit but if it's for both then your deal that was charged to you was too much. Seems like these guys (Aviation Enterprises) are just shooting from the hip on items and not very consistent.
Unread 04-02-20, 11:15 AM
Jhogan0101's Avatar
Well i paid $2995, and only received the rear. Then i called Owen and he said that its not his fault i didnt get it and he would send the front one for ONLY $995. Im working with Don Nieser, he said he may have the cable i need for $150.
337B
Philadelphia PA
