Unread 01-01-20, 03:09 PM
gear Warning Horn
I think this has been discussed several times, but looking to get some help. Today, I took two flights, on both flights, gear up, throttle open, green light and pump not running. Gear horns sounds, non-stop. I am thinking it is the micro switches in the throttle body. Thoughts?
Unread 01-01-20, 03:12 PM
99% probability its one of those microswitches
Easy to adjust (given small screwdriver and nimble fingers).
Easy to replace.
A common 'microswitch' ...if you're not too hung up on FAA sourcing.
Easiest to wire to switch off aircraft on bench, then splice in wire.
Unread 01-02-20, 06:50 AM
Gear horn
Where are the switches. In the control quadrant? On the engine? I have the parts manual. But it is not clear, at least not to me.
Unread 01-02-20, 07:53 AM
Switch location
On top of engine, side of throttle assembly.
Where throttle linkage connects.
An eccentric cam on the throttle shaft opens the switch.
Failure mode is “GAW GAW GAW GAW.”
Unread 01-02-20, 05:28 PM
Gear Horn.
Found both switches. Interesting little setup. In either case the front engine switch is frozen, so regardless of the position of the cam switch remains closed. Rear engine operates normally.
Ordered a new switch. $20.00 so not so bad and frankly not worth bypassing.
Will install over the weekend.
Unread 01-19-20, 05:44 PM
Gear warning horn
I did my tests last week and all is well. 20.00 on replacement wait h and a few wire connectors. Small piece of advice for anyone trying this....make sure you put a clean rag under the assembly. The lock washers and nuts are small and easy to drop. Much better if you have a limited area to search.
Unread 01-20-20, 01:18 PM
rmorris rmorris is offline
Originally Posted by frank.oconnor19 View Post
I did my tests last week and all is well. 20.00 on replacement wait h and a few wire connectors. Small piece of advice for anyone trying this....make sure you put a clean day under the assembly. The lock washers Me nuts are small and easy to drop. Much better if you have a limited area to search.
You pulled the cessna part number out of IPC, or found a better source for replacement microswitch?
Unread 01-20-20, 01:50 PM
Gear warning horn
I have the Cessna parts manual. So got the part number there.. it has been superseded so I used the newer part number.
Unread 01-20-20, 08:26 PM
cessnadriver's Avatar
gear Warning Horn
Frank.
Just asking-but are you sure it's the gear horn?? I had a horn, thought it was the gear but found out it was the stall portion of the horn going off. I had pressure washed that wing after stripping! Water in the stall switch. FYI.
BILLS
Unread 01-23-20, 05:17 PM
GAdams GAdams is offline
Where
Where do I get those $20 micro switches and what is the part number?
Unread 01-23-20, 06:06 PM
gear warning horn.
so here is the link to the page on airpowerinc.com
http://www.airpowerinc.com/productca...dioGroup=radio
attached are pictures from the parts manual for my plane with the location, top of the engine, and part numbers. hope this helps. BTW the part number in the book, USM5W was replaced by S1856-1
Frank
