Unread 11-02-19, 11:35 AM
Bobcllns P337 Bobcllns P337 is offline
Bobcllns P337 is on a distinguished road
Defrost air flow
Hi everyone
For some reason I cannot get any airflow coming out of my defrost on my Pressurized T337G. We have chased all the scats and replaced the collapsed/damaged ones, verified all the valves and control cables which appear to work normally. Is this a problem on the pressurized 337 and does anyone know of a fix for it?
Unread 11-04-19, 07:16 PM
kilr4d's Avatar
kilr4d kilr4d is offline
Bob, have you got a leaf blower to connect to the scat tubes and confirm that the valves are opening?
_________
John K
1977 337G
CNC3
Unread 11-05-19, 10:04 AM
I do great idea will try it today thanks
Unread 11-06-19, 08:19 AM
Thanks for the tip John. I did get some airflow out of the defrost, enough to make a tissue move and much better airflow out of the vents below the left and right seats. I guess my recirculating fan needs to be replaced $$$$
Unread 11-06-19, 08:29 AM
kilr4d's Avatar
Ask your A&P if he'll let a motor shop that works on DC motors take a look at it. It's becoming more common as the legacy fleet ages and parts cease to become available. If they can find an issue with a bearing/winding/shaft etc maybe he'll sign it off.
_________
John K
1977 337G
CNC3
Unread 11-06-19, 08:51 AM
John, I just had the motor fixed so I believe the squirrel cage is allowing bypass since I get good airflow from it but no pressure
Unread 11-16-19, 09:52 AM
1969 version
My older T337D relies on ram air pressure, so you only get good defrost in flight.
On ground, not much at all, just from front prop backwash into ducting.
The only motor is the one mounted on the heater for combustion air flow.
You 'throttle back' that back (partially close duct) in flight because adding ram air is too much.
