Unread 12-11-02, 06:18 AM
Right Brake Going Flat.
Merry Christmas to you all!
Has anyone suffered the right brake going flat on a regular basis? What seems to be happening is that the right-hand master cylinder, which is higher than the left, cross feeds to the left-hand master cylinder through the parking brake assembly. It over flows fluid in to the hull we presume. If you pump fluid back up from the brake bleed fitting you restore brakes immediately. My A&P and I figured we had it fixed when we replaced the parking brake, but yesterday it happened again. Much frustration! Any comments and suggestions would be gratefully received.
