Unread 08-05-19, 08:30 PM
Engine Driven Hydraulic Pump
Purchased the pump with the intention of putting on the rear engine of my 1965 Skymaster to make it a dual pump system for redundancy. Have since decided to part the aircraft.
Asking $700
Unread 08-06-19, 11:51 AM
Pump
Do you have a part number? is it Yellow Tagged?
Unread 08-06-19, 12:56 PM
Yes. I will get the part number tonight.
Unread 08-08-19, 08:50 PM
I did not bring the pump down from my hangar, however, I will be up there this weekend and will have pics and part numbers for you.
Unread 10-20-19, 01:00 AM
Do you still have the pump?
Unread 10-22-19, 05:05 PM
Pump
I still have the pump if you are interested. I also have the bulkhead filter assembly and backflow valve if you are trying to add a second engine driven fuel pump to the rear engine of your skymaster.
Unread 10-22-19, 05:14 PM
Yes. But please confirm the part number so I can confirm it’s application on my plane.
Txt I ok. 505-459-9230.
