Unread 07-19-19, 04:11 PM
Smile Specific steps to replace (outer) side windows - de-rivet?
Good evening all,
I am seeking answers and truth BEFORE disemboweling the interior of my 337.
To determine if said disemboweling is even worth the hassle in the first place.
The T337 has double side windows, inner and outer.
QUESTION: Can anyone give step-by-step instructions/guidance/photos on replacing the OUTER side windows on a T337?
Yes, yes, I know
you pull the inner trim fairings and the inner windows pop right out.
All well and good. That's easy.
As 'they' say, "Duh..."
BUT....I am CONTEMPLATING replacing the outer windows, which are surrounded by scary rivets.
While attempting to polish same, it appears there are vertical 'frame' pieces front and back of each window that simply unscrew. By (simply) removing those pieces do the outer windows (with frames) pop out, or must one de-rivet the 10,000 scary rivets to get the outer windows out? (And therefore same to put back in, then repaint, then...etc.)
Maybe same for P337?
Then of course, any thoughts on the installing outer windows into their 'frames?'
Muchos gracias 'thrasher amigos,
