Unread 09-03-17, 03:55 PM
N31LC N31LC is offline
N31LC is on a distinguished road
Front engine fuel strainer
Guys quick question...front fuel strainer is not sealing correctly causing a fuel leak. I removed the fuel strainer from nose gear compartment and have it pulled a part. The question I have is the oring inside the mechanism ? And can it be replaced or do need to buy an entire new strainer
Unread 09-03-17, 07:26 PM
cessnadriver's Avatar
fuel strainer
Hello. Are you asking about the o-ring in the top of the strainer? ALL o-rings are replaceable. Top of case o-ring PN: MS29513-10, o-ring around top of Bowl PN: MS29513-138, o-ring Bottom of bowl PN: MS29513-111. Hope this helps.
BILLS
Unread 09-03-17, 08:25 PM
Yes when I pull the plunger up and down I can't see the O ring ...part number 12 in the service manual page 11-27...how can I get that out ...should I just replace the strainer ?
Unread 09-03-17, 08:27 PM
Ok ..sorry just got it out..where is best place to get O rings...need all of the O rings. They are all old. The standpipe also hassome corrosion. Basically a rebuild
Unread 09-04-17, 07:15 AM
Red face Front engine fuel strainer
I routinely use Aircraft Spruce. Although for a rebuild kit I used, for my Cessna 172, McFarland Aviation. You list your aircraft model and serial number and they'll shown you if they have a kit for your airplane. Good people and friend service.
BILLS
