Unread 08-18-16, 07:06 AM
pilotpat pilotpat is offline
pilotpat is on a distinguished road
Insight Flow sensors onto an IO-360-GB
This is research for a G4 Twin engine monitor install.
Anyone have experience (and possibly pictures) of installing Insight Avionics flow sensors onto an IO-360-GB engine (337H)? Their website shows it to be (without fittings) 2" long in the flow direction x 1.77" (about twice that size once you add fittings and electrical connector) x 1.65" high. Best place I can figure to put it is under the alternate air scat hose with new inlet and outlet ho$e$, assuming the hoses can be prevented from moving. Insight details the sensor to be level with straight runs in and out to avoid turbulence.
Pat
