Unread 07-09-16, 04:56 PM
rmorris rmorris is offline
alternator diode assembly
There is a diode assemble, with small circuit board, in a plastic box mounted to rear firewall (similar on front firewall). the connection on the top of the diode broke off. enough to make it tough to field repair, think I would like to get a replacement diode (the circuit board is likely fine).
1) does anyone have an extra one in a plane being parted out?
2) anyone have a clue for a current part number for that diod (which looks like a heatsink btw, with diode looking connection on top and bottom)....in the PC, I think it is 157C090-1...but a google of that part number, checking it on controller.com and checking iwantcessnaparts, all turn up nothing.
any thoughts?
Unread 07-11-16, 12:18 AM
I'll get you the P/N in the morning. You can get them at electronics supply places a lot cheaper than Cessna
Unread 07-11-16, 10:11 AM
diode p/n
Kim, that would be awesome. I anxiously await it
