Unread 01-01-16, 09:45 PM
DrDave DrDave is offline
Picture Request
Greetings and Happy New Year:
I would like to see some avionics bay pictures. I am particularly interested in pictures of a behind the panel picture of any Garmin G500/G600 installations. I am planning an avionics upgrade and would like get a look at various layouts.
Thank you.
Unread 01-03-16, 05:46 PM
Hi Dave
Not really sure if these photos will help in your request but this is my panel back in 2004 when I did the last upgrade. I can take some other photos if you have any other ideas what you want
Cheers
ID:	1620   Click image for larger version
ID:	1621   Click image for larger version
Unread 01-03-16, 07:07 PM
Thanks Herb:
I've been cleaning things up behind the panel. It looked like someone dumped a box of wire behind the panel when I started. I'm getting it all cleaned up. I'm working toward a G500 install with a few of the add-on boxes. It needs to be clean behind the panel to make a nice install. I pretty much have the co-pilot side under control. Next stop is replacing the dimmers with Max Dim units from Max Pulse/Max Dim. It is helpful to see the layout of other peoples panels.
ID:	1623   Click image for larger version
Unread 01-03-16, 08:09 PM
Max Pulse are nice units, I have two of them for my compass and panel lights. Good luck on the project
