Old 12-20-15, 10:58 PM
chrisskymaster chrisskymaster is offline
chrisskymaster is an unknown quantity at this point
Rudder Pedal Pressure Before and After Gear Retraction
Hello All. Would like some feedback please. I might be imagining things but I had my mechanic swing my gear a few weeks back and I notice a difference in rudder pedal pressure in flight before and a after gear retraction. While on the ground taxing, and when in flight before the gear is retracted, the rudder pedals feel typical (they don't require much pressure when I depress the left or right rudder pedals. After gear retraction, I notice that the rudder pedals feel much firmer. I am suspecting that this is a result of a more compressed steering bungee after the nose gear is folded up and put away. Can anyone else share with me what their rudder pedals feel like before and after gear retraction. On my bird, everything works just fine but I am wondering if you all experience a difference in rudder pedal pressure before the gear is retracted and after the gear is retracted.
Thank you so much.
Chris
Old 12-21-15, 09:00 AM
It's normal to feel a difference when the nose gear is retracted. As retraction is in motion there should be a noticeable locking bump as the nose gear is nested in the lock track and rotated 90 degrees so that it will nest in the gear compartment. It's just a split second feel as the gear goes up and will have a different feel to the pedals like there is a little more load or heaviness to the pedal.
Old 12-23-15, 10:11 PM
Rudder pedal pressure
Thank you Herb.
Happy holidays.
Chris
