Unread 10-27-15, 09:24 PM
frfly172's Avatar
frfly172 frfly172 is offline
frfly172 is an unknown quantity at this point
Pirep c336
Considering purchase of a 336 , flew one for an hour ten years ago,interested in pros and cons from 336 pilots or owners. Thanks Ron.
Unread 10-27-15, 11:50 PM
Use the search feature
I my humble opinion, why buy a 336? Unless there is some kind of nostalgic reason, the 336 is going to be same ownership costs as a 337. Except for maybe some unusual gear issue or something, but the engineered changes on the 337 over the 336 is worth that risk. Just my opinion.
Here are some threads that might help. Used the search feature of the forum
http://www.337skymaster.com/messages...highlight=C336
http://www.337skymaster.com/messages...ht=differences
BTW, had my Skymaster at your airport a couple years ago, nice field.......
Unread 11-15-15, 04:37 PM
James T Grant James T Grant is offline
James T Grant is on a distinguished road
Thumbs up C336
Dear All,
Having owned Skymasters of many types including early Non-Turbo and Turbo, late Model Non-Turbo and P through a Riley Super with the TSIO-520s, I am happiest with my 336.
It is simple. Very cheap to maintain and has 932 pounds of payload full of 128 gallons of fuel.
It will not only fly comfortably on one engine at 5000 ft MSL at my normal 500 pounds below gross weight, but will takeoff from 700 ft MSL on a 90 degree F day with either engine left at idle.
The comfort level this gives as I load my wife and kids is reason enough. (Empty weight of my 336 is 2200 pounds after a serious diet program)
It has the Horton STOL kit with droop tips as well as the VG kit, but these are cheap enough and have added greatly to the original climb and Single Engine performance.
My Longest regular trip of 800 NM from North Alabama to Eleuthera takes 6.5 Hours flight time plus a fuel stop. (Cruising at 140 Knots TAS)
In my 1967 337 the same trip took 5.6 Hours plus the fuel stop (Cruising at 155 Knots TAS). With this amounting to less than 30 mins per leg difference, I felt and still feel that the simplicity of the fixed gear and excellent single engine performance make the trade well worthwhile.
Of course, with only a handful of 336s still flying a good example is hard to come by so one of the more plentiful early 337s may be the only real answer.
Fly safe.
Regards,
James
