Unread 03-31-15, 10:06 AM
sunnysky sunnysky is offline
Avionics master switch
Hello everyone.
I need a new avionics master switch for my trusty 1977 Skymaster.
it is an origonal rocker type switch mounted in the circuit breaker panel on the L/H side of the aircraft.
any ideas where I can locate one ?
Think one from Cessna would exceed the value of the aircraft !!
Thanks everyone
Unread 03-31-15, 04:09 PM
Most likely your "trusty" Skymaster has a built in avionics power switch
Part #S2281-1 - Avionics Power Switch @ $434.78 each from Cessna Direct
http://www.cessnadirect.com/search.p...=search&page=1
You could check with Commodore Aerospace, although he stocks mostly earlier model parts, as they are new military surplus. Don can be reached at - nieser.02.337parts@juno.com
Also check these sources
http://www.controller.com/list/parts...1-1&pst=starts
