Closed Thread
Unread 08-17-14, 03:09 PM
Pick up Coil on Mag
Is anyone familiar with the tach pick up coil on the mag of the C336? Part number or any info would be appreciated
Is the number a S1512-2 which is now 10-187065-1?????
$659 at yingling but not sure this is the right unit
Unread 09-03-14, 02:48 PM
Part Number
Herb, yes the original Tach Pick-up Coil was S1512-2.
Don Nieser(02 and 337 parts guy)
Commodore Aerospace Corp
405-503-4686 cell
nieser.02.337parts@juno.com
www.02337parts.com
Unread 07-24-18, 01:50 AM
AV8ing AV8ing is offline
I'm bumping this old thread since we have a dead tach on the front engine that I need to troubleshoot.
What is the most likely cause and can I assume that it is indeed a magnetic coil that sends the signal to the gauge and NOT a breaker unit as suggested in the SM ?
Thanks!
Unread 07-24-18, 09:00 AM
Frank Benvin's Avatar
Thanks!
Swap the wires on the gauges to test if the gauge is bad Most likely the pick up coil or broken wire I just replaced the one on my rear engine
Frank
Closed Thread
