Unread 05-03-14, 04:26 PM
B2C2 B2C2 is offline
Cigarette lighter fuse location
The lighter socket is out on my 1969 T337D. According to the schematic there is a fuse in series with the breaker. I've looked around and can't locate it. Can someone tell me where this fuse is located? Thanks for any help.
Unread 05-06-14, 10:59 AM
I have found a reference to this fuse in the service manual. It says it is located on the same frame member behind the throttle cluster as the 1.6 ohm resistor that is also in series with the breaker. I've located the resistor, but there is no sign of the fuse. Was this supposed to be removed at some point, or did folks remove it since the circuit has a breaker anyway? It is on the same breaker as the landing lights, which is 8A due to the dual light configuration on this airplane.
