Unread 07-15-13, 10:48 PM
Rear engine baffle CAD models-rear engine
Hey guys,
I have reverse engineered my rear engine cooling baffles for my skymaster and wanted to see if anyone was interested in me posting them here for all to use. You can have a fab shop cut these out of 6061 or 5052 for a couple of hundred bucks and bolt them together so you can replace cracked parts without having to remove a big section of the baffling and drill rivets.
My aircraft is a 1965 normally aspirated model
I have these in solid works format but can export in other formats if you need them.
I will post some pictures, screen shots soon.
Unread 07-16-13, 11:07 PM
cessnadriver's Avatar
YES.
I have 1965 C337-project, and would like to see what you got! My baffling is NOT in terrible shape but I could use some help with the seals around the sheet metal. Will your pictures help with this?
Thanks.
BILLS
