Unread 10-10-02, 07:41 AM
WHY a 337? ....because they are forgiving
Accident occurred Tuesday, February 25, 1997 at GOLOVIN, AK
Aircraft:Cessna 337C, registration: N2615S
Injuries: 1 Uninjured.
The pilot was en route to his intended landing point over a portion of frozen ocean ice in a twin engine, centerline thrust airplane. He was flying about 100 feet above the ice to remain below an area of low and obscured ceilings. Visibility was about 6 miles, but flat light conditions prevailed. While in cruise flight, the airplane suddenly collided with an unknown object. The front engine developed a severe vibration, and the pilot was unable to feather the engine. He continued to the intended destination and landed without further damage.
An inspection of the airplane revealed that the front engine propellers were bent aft about 14 inches. The blades struck the nose gear support structure. The right step was torn from the airplane and produced about a 12 inch gouge in the fuselage.
The pilot was informed by local residents, that a large ice pressure ridge had formed in the area of the accident. The ice ridge, as reported to the pilot, was estimated at 35 to 40 feet high.
The National Transportation Safety Board determines the probable cause(s) of this to be...............................
Hmmmmmmmmm
Unread 10-11-02, 06:34 PM
Talking pulling my leg?
Hey Bob, Is that a true story or are you trying to get a string going here? Sounds fishy to me!! It does however make good listening!!!
cheers
Unread 10-11-02, 09:21 PM
It is true. Look it up on the NTSB websight.
NTSB Identification: ANC97LA029
Accident occurred FEB-25-97 at GOLOVIN, AK
There is another one where a 337 ricoches off the water (gulf) and makes it back to Miami with TWO BENT props, bent gear doors (torn off) and bent bottom panels. This is one of the Cuban refugee search aircraft. Can find the details on the NTSB websight as well.
FYI
