Unread 04-14-13, 10:59 PM
rear alternator light
Let me preference this question with the fact that I have read all the threads on the above subject and have not found any reference to a similar situation.
Problem: Rear alternator light and discharge light stays on at all times when battery switch is on.
If front alternator is turned off ammeter shows positive amps and JPI 760 reads 28.4+ volts from rear alternator, only indication that anything is wrong is the fact that the alternator light is on. Full field test of rear alternator checks out as normal. Voltage regulator checks out as operable. Found a broken wire on capacitor and replaced---no change.
Only thing that has changed when this issue came up was that we had completed a major on the front engine.
Any suggestions??
Unread 04-15-13, 09:10 PM
What flavor of Skymaster do you have?
Unread 04-15-13, 10:54 PM
1973, T337G, s/n P3370018, Pressurized
Unread 04-23-13, 01:21 PM
More than likely is that you've got a blown diode on the little signal processing board on the top center of your firewall. Or possibly a bad relay on the same board. The diodes are very easy to replace. I would disconnect them one at a time and check them first. There are a total of 4 of them, 2 for the front engine, and 2 for the rear engine circuits. There is one relay for each circuit. There is also a fuse for each circuit.
Mark Hislop
N37E
Unread 04-23-13, 07:07 PM
Thanks Mark.
When you converted to 400 series alternators what was eliminated on the old parallel board?
Unread 04-23-13, 07:11 PM
Although I could have eliminated the parallel board (I installed a volt/ammeter) I left it in. I still like having the "idiot lights" in my scan.
Mark Hislop
N37E
Unread 04-23-13, 07:18 PM
So I would still need to fix issue I am now having?
Unread 04-23-13, 10:03 PM
I don't think you have a real issue. It sounds like your electrical system is working. You just have a metering problem, and you are getting false indications. As far as I know, the parallel board only monitors the current flow of the two alternators and compares them against each other. As long as you have a volt meter and an ammeter, I believe you can remove the board.
Mark Hislop
N37E
