Unread 06-14-11, 04:12 PM
travis's Avatar
travis travis is offline
Unhappy need part no. HELP
Anyone know the pn. for the AN union that brings pressurized fuel pressure to the fuel flow gauge on the FWD bulkhead? I can't find it in my MM or PM. Only similar part I could find was for the oil pressure and it's just a standard AN832-4 fitting... I'm told that the one for the fuel has a metered orifice and I can't seem to nail down the pn...
your help here is appreciated
_travis
Unread 06-15-11, 04:13 PM
I think it's S2289-3 fig. 109 item 21
Unread 06-15-11, 05:43 PM
Working with Kim's information, I came up with something different.
For 73-76 models, the applicable figure is indeed 109, but my IPC doesn't show part 21 as S2289-3 (the S means it's a standard part made for many aircraft, not just Cessna). Instead, for those model years, it shows 1450024-1, which would make sense if it's a Cessna part with a metered orifice.
For your model, the 70-72 IPC has this as Figure 134, shown below. I've put the part numbers at the top right of the figure, and part 21 is also 1450024-1.
Kim (who I was fortunate enough to meet at our first Skymaster Fly-In at a Bahamian out-island in 2002) knows far more than me and it's my go-to guy when I'm having technical problems, so his answer -- not mine -- may be the right one.
Name:	MP&FF Install.jpg
Unread 06-15-11, 07:56 PM
Ernie is right the P/N is or was 1450024-1 but my book for a 78has WEU S2298-3.
The WEU means "when exhausted use"
Unread 06-24-11, 06:16 PM
travis's Avatar
Thumbs up
thanks for the help fellas... I got a new used one and all is good.
