Unread 11-01-10, 04:17 PM
Osage2112 Osage2112 is offline
Osage2112 is on a distinguished road
Cost per year over 10 years
Is the cost per year over 10 years, (insurance included) comparable to other twin engine planes?
Is the 337 average or is it truly more expensive to own???
I've heard the 337 is more expensive, but that could be due to an abused plane needing to be "caught up" on maint.
I'd like to consider a 337, but need to know from the forum first.
Osage
Unread 11-01-10, 11:14 PM
Roger's Avatar
Roger Roger is offline
There are a lot of posts on here about costs. Suggest you search, and if that doesn't answer everything, ask specific questions. However to compare you will have to do like research on other aircraft web boards, or talk to owners of other aircraft types, and models.
And of course each operators idea of what is "flyable" will directly affect the actual yearly expense of any aircraft. Especially as they get older.
Good Luck with you choice.
Unread 11-02-10, 04:23 AM
I have a 68 C model 337 and I own 1/2 share in a Piper PA30 Twin Comanche. Insurance is a little more on the TwinCo and the 337 burns more fuel, 17 vs 22. The TwinCo with it's 4 cylinder Lycoming IO320's are easier on OH and Annuals. The Lycomings are 2000 hr TBO and the Continental IO360's in the 337 are only 1600 hrs, but nobody OH's at TBO. Lot's of info on the message board about the OH on the 337 engines too. You will find that the 337 is just a little more finicky when comes to maintenance and annuals. Find a good AP/AI that knows the aircraft and it won't be too bad. Stuff like gear swing, rear engine, booms and tail are all a lot different than the TwinCo but once you have done it a few times it's just another day. The 337 is much easier to enter and exit. No climbing up on the wing and falling into the cabin. The other nice advantage for the 337 is you can see out of it. Flying the TwinCo provides NO visual under and limited to the lower sides. Neither aircraft are for the light-hearted. Be prepared to spend a sizable chunk of annual money to keep these guys in the air. I figure my annual fixed costs to be around $10,000 with hanger, this is before you start the engine and add reserves for the engines. It's getter tougher and tougher each year to keep this up. I don't really know how long I can continue without seeking a partner or help in some way. My annual flying has gone from 120 hrs to 60 hrs in the last several years. Each time you go for the Saturday pancake run on the weekend it's $175 for fuel. I don't even think about the other hourly expenses or I probably would just park it. It's not a 182, so be prepared to keep the aircraft airworthy it's going to cost.
Unread 11-02-10, 05:11 PM
Compared to Seneca
I have had a 73P337 since 1996, and I had two Seneca II's before that. They all had the same engines (TSIO360's) and are approximagely the same "mission capable" aircraft. The biggest difference is the pressurization of the 337.
The Skymaster is a little harder to work on, particularly around the engine compartments. I've never had a pressurization problem (probably just jinxed myself) and the pressurization system is pretty simple. The overall costs of maintenance has been about the same. The annual for the Skymaster is probably a bit more expensive, but the fuel burn is less. All in all, pretty much a wash. A well maintained 337 should not be drastically different costwise compared to another aircraft that fits the same mission, at least based on my experience.
Mark Hislop
N37E
