Old 01-29-09, 08:51 PM
Cold Weather Propeller Operation
I read an interesting article, recently, about cold weather operations. In it the author says that the oil in the prop does not readily mix with the engine oil. During a normal shutdown, oil is trapped in the prop. That oil would then not heat up, as readily, as the engine oil.
If the engine oil temp is coming off the mark, getting warm, it is possible that the oil in the prop is still too cold to permit normal operations.
It just sounded right to me, and I thought I would pass it along.
