Unread 06-30-08, 07:25 PM
tropical tropical is offline
Diode Part numbers
Does anyone know the part number for the diodes that sit right behind the alternator fuses in the front engine compartment? These diodes screw into a large heatsink. They have a shaft with a hole for a screw and the bottom looks fit a 1/2 inch socket. I have one that has a broke shaft and need to replace it. We have a large electronics store here in Orlando and I would like to match it up.
The book says it's a 70 amp diode. If I read the wiring diagram correctly they are the diodes for the alternator out lights.
