Unread 01-11-08, 05:23 PM
tropical tropical is offline
wiring book 1974 G model
Anyone have access to a wiring manual for a 1974 G model? Mine grew legs and walked away.
I need to know what a coax that has number 3980107-2 goes to. I believe it's a comm but want to be sure.
Unread 01-11-08, 07:41 PM
Your number does not appear in the '73 - 76 parts catalog, so I believe it's not a Cessna P/N. If the wiring manual cites only Cessna P/Ns, it may be hard to figure it out based only on this number.
Unread 01-11-08, 08:02 PM
It's not a part number, but a wire number and can be found in the wiring manual.
Thanks.
Unread 01-12-08, 01:25 PM
I have had a look thru the Avionics Installation manual and cannot find that wire number.
Pete
Unread 01-12-08, 01:45 PM
OK, thanks. It was probably marked by an avionics installer sometime back.
Just curious, what does the manual show
wire number for the coax's for com and nav?
Unread 01-12-08, 02:54 PM
I have the following
ADF- 3980124-2
G/S- 3980153-2
HF - 3980118-1
3980119-1
VHF 3980111-2
3980106-1
3980108-1
TPR 3980103
NAV 3980132-1
Hope this helps
Cheers
Pete
