Unread 12-29-07, 06:55 PM
A VAR question?
Can a VAR crank be put into a light case? Or does a VAR crank require the heavey case?
Also, how can I determine if the case is light and or heavey?
Unread 01-02-08, 06:11 PM
SteveG's Avatar
SteveG SteveG is offline
Yes. No. The "heavy" case will have reinforced bolt holes along the top case seam resulting in a scalloped edge, the "light" case will be flat along the length of the top case seam.
