Old 12-19-07, 11:16 AM
cessna02337's Avatar
cessna02337 cessna02337 is offline
cessna02337 is an unknown quantity at this point
Need Help with a landing gear problem O-2A
New to the 02/337, have a quick question for the group.
I have two problems happening with my gear system that hopefully can be solved with the group's great experience base.
1. When I retract the gear to the up position, everything works properly, but gear handle does not reset to the neutral position or out of the up position when finished. I have to manually place out of the up position to the next detent position below up.
2. When I select the gear down, I must hold the gear handle in the down position long enough to ensure the doors close fully, gear then spring loads to the next up detent as it should. If I just put the gear handle down and don't hold the handle down, part of the gear doors will be open for landing.
What I have been doing to overcome #2 is to hold the gear in the down position for several seconds, then let go and all seems to go well.
Thanks in advance, Tom
