Unread 07-19-07, 02:46 PM
bncme262 bncme262 is offline
bncme262 is an unknown quantity at this point
Rear engine needed maybe:
I could use a little advice and possibly a rear engine. I was told by the seller that the rear engine had a prop strike and now it has an oil pressure problem. Here's the question: on an engine with good oil pressure, if you pull the plugs (i should ground the spark plug leads to prevent damage to the bendix magneto?) and spin the engine will it inicate, show or build up any oil pressure using a mechanical guage hooked into the engine, or does the engine have to start to show oil pressure. could the oil pressure problem be due to a weak spring on the or stuck open oil pressure relief valve and could i possibly restore oil pressure by injecting oil (pump lost it's prime after sitting) or by putting in stronger springs on the op relief valve. or do i have to start the engine to confirm the lack of oil pressure? to get at the oil pump on the back engine am i better off to pull the engine? has anyone pulled the oil pump by going in through the interior and the back firewall or is that just not worth the trouble? my experience has been in car engines where you could pull the plugs, spin it on the starter and get some oil pressure? thanks f0r help and advice. when did the var cranks start appearing, what year and model engine s and skymasters? it's a 1966 337A with engines over tbo.
