Unread 03-18-07, 10:21 PM
gfcudahy gfcudahy is offline
gfcudahy is an unknown quantity at this point
Electroluminescent panel lights
Does anyone know how the Electroluminescent lights work? My power supply puts out the variable AC volts up to about 115 volts with the panels disconnected or with only the flap panel connected(it works). The problem is the switch panel light on the pilot side. Before powering up the pilot side light (and disconnected from the power supply) it has a resistance of approx. 100-140k ohms. When connected by itself the power supply will only put out about 10-15 volts at max. Immediately after disconnecting the switch panel and checking the resistance again I get about 50 ohms. Is there a way to fix the panel or remove its connection at the panel or???????
Thanks.
George
