Unread 02-26-07, 01:17 PM
Pressurized Mags
Hi All,
Does anyone have pressurized mags on their bird? If so I would like to find out some stuff.
Ed Coffman
Unread 02-26-07, 01:55 PM
I installed the pressurization kit from TCM on Piper Turbo Arrows and Seneca's. A real tidy and simple task.
Tapped into the upper deck with a 1/4 line, thru an inline air filter, a "T" fitting, then to the two mags. The line went into the tapped hole on the magneto at the distributor gear.
Unread 02-26-07, 04:23 PM
Press Mags
Yep, I do! It is N34EC. What info do you need?
Unread 02-26-07, 05:07 PM
Hi Jerry,
I assume you have a P337 and are using the Riley STC. My question is: what is the mag part number you are using and is the tach drive still run off the mag? I have a T337H and am investigating the possibility of pressurizing the magnetoes.
Ed Coffman
Unread 02-26-07, 06:10 PM
mags
I'l get the mag number for you next time I go to the hangar. I can tell you now, the tack drive is driven off the mag.
Unread 02-27-07, 08:24 AM
But the tach sensor is on the bottom hole, the one closest to the rotating magnet. The pressurization air goes into the other hole, the upper one.
Unread 02-27-07, 09:16 AM
mags
When I go to the habgar this week I will look at and and let you know>
Unread 02-27-07, 11:30 AM
djarrett djarrett is offline
djarrett is an unknown quantity at this point
Pressure Mags
Don't forget to plug the little hole in the bottom or everything is for not. I learned the hard way and couldn't figure out why no pressure mag. Works great with a little screw in the hole.
DJarrett
Unread 06-15-15, 04:23 PM
JamesC JamesC is offline
Does anyone have the part number for the in-line filter made by Continental?
I need two of them as my mechanic noticed they were absent. I read on another thread something about upper deck air being clean, but the problem is any oil that may eventually leak from a turbo could get into the mags.
Thanks!!
Unread 06-18-15, 04:15 PM
Thanks!!
The P/N is 653386
Kim
Unread 06-19-15, 05:52 PM
Thanks guys - RAM looks less expensive - will likely go with them. Both have improved models with a drainage port for water etc.
