Unread 01-29-07, 02:03 AM
Landing gear problem
Today I found alot of hyd fluid on the ground. I was able to discover the source. There was a hyd line that broke because of chapping. Right under the main gear actuator are hyd lines. It seems the rotating gear shaft has some screws/nuts that rubbed, over time, on the hyd lines. This made a very deep cut in the line.
I highly recommend you check your hyd lines for this sort of rubbing.
Rob
