Unread 12-16-06, 10:33 PM
Paul462 Paul462 is offline
Question Rear cowl flap motor intermittancy.
Help!
Last Sunday upon landing, the rear cowl flaps were still full open, even though the handle on the panel had been in the "closed" position for the previous 45 minutes. I cycled the rear cowl flap panel handle handle several times, and the rear cowl flaps didn't move.
A few days later I turned on the master switch, and the rear cowl flaps closed (the panel handle was in the "closed" position) - the cowl flaps worked fine, and the mechanic could find nothing wrong with them!
Has anybody had a similar experience, or might know what could cause the rear cowl flaps to freeze up when the engine was hot, and then work completely normally a few days later?
Thanks!
Paul
Paul
T337C
