Unread 07-10-02, 06:41 PM
Angry Fuel Leak
I'm still struggling to identify a fuel leak in the left wing, not a big leak but big enough to drip into wing when full run down the inside and stain side of cabin.
But after removing all inspection panels and finding no leaks it appears that the leak is in the top connecting hoses between the inboard tank and the middle tank (by deduction as capilliary action between the skin panels shows slight staining up to the boom but not past it and up to the forward 1/3 of the wing) and (also the boom sump has no leakage) ...oh forgot 1973 C337 G 118 US gallon tanks
Only happens when full, If I remove boom sump panel will this allow me to access the connecting hoses between these tanks. If it's not this then I'm stuffed unless there is some other obscure place that it can come from
Any help welcome...and GMAS thanks for previous help but I think this annoying little sucker is going to be one of those hard to find things.....nearly forgot the tanks were removed 18 months ago refurbished, pressure tested and reinstalled and checked out ok
Regards..........Wayne
