Unread 06-19-02, 08:34 AM
Post Valve Cover Gaskets
At TC, GMAS talked about stuff you can spray onto valve cover gaskets, that is an adhesive, and seals up all the leaks. I presume he was talking about something that is used when you put new valve cover gaskets on. I have some on order (finally stop the leaks on the rear engine), and wanted to get the spray stuff.
Does anyone remember what the stuff was?
Is this something that you use with the silicone gaskets? BTW, www.realgaskets.com sells these for about 1/2 the price of Chief.
