Unread 06-19-02, 07:15 AM
SKYMASTER44 SKYMASTER44 is offline
SKYMASTER44 is on a distinguished road
Question Flap Adjustment
1966 337A (yes I have the manuals)
Is there any easy way to adjust the travel of the flaps, to achieve the 25 dgs? and have the flaps
tucked in the up position nicely? Any tricks?
Where to stick the 3/16 rig pins? the manual is very obscure about it.
Tony P.
Unread 06-21-02, 05:45 PM
If you're not an A&P mechanic, you should not be tinkering with flight contol adjustments. If you are an A&P, following the manual will get you in the right direction.
FAR 43 is quite specific on what an owner/operator is allowed to do as preventive maintenance. Any more than that requires mechanic supervision to accomplish.
Knoxville, TN
Unread 06-24-02, 12:52 PM
Smile Flaps
The only task I can not do legally (not yet)
is to overhaul the props.
Tony P.
